585,555 active members*
3,355 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Index and Traub > GS42 stands still with programmed bevels.
    Hello,
    I have a problem with our Index machine.
    Today the GS42 began to refuse turning of programmed bevels.
    It stays and waits for something.
    If I change to the single block mode, the bevel is made. If I change to automatic again, the machine works until the next bevel comes.
    If I program it manually, it works
    G1 X28.8 Z.05 F.1
    X29.8 B-.5
    Z-20 B-.5
    X28.8
    Doesn’t matter, with stress corrosion cracking or without it. The machine stands still.
    G1 X28.8 Z.05 F.1
    X29.8 Z-.5
    Z-19.5
    Z-20 X29.8
    I have already made the drift calibration.
    MD 231 and 232 with Edit + S. Everytime the value changes.
    It’s most between -4 and +3
    Does anyone have an idea?
    Jun 2004
    119
    Hello
    Does the machine have Sinumerik 3 controller?
    According to the drift calibration bits, it is so.
    Is the option bit changed?
    Bevels and radius are options.
    Regards
    Ludwig
    Controller is S3T. Option bit is set.
