585,931 active members*
5,438 visitors online*
    Hello
    What could be the reason that the SCARA cancels after every cycle stop?
    Best wishes
    <!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><!--fonto:Verdana--><span style="font-family:Verdana"><!--/fonto--><b>Wenn Google mal wieder Streikt, ist das Internet dann nicht kaputt?</b><!--fontc--></span><!--/fontc--><!--sizec--></span><!--/sizec-->
    Hello I can’t quite follow your question.
    Maybe you explain what example you mean
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
    Feb 2008
    Hello
    In the area of a few 1/100mm it’s normal that the axis go out of control at the cycle stop.
    But it’s no problem because usually at the start of the program, the spindle middle is approached with the swiveling cycles.
    The SCARA axis regulates itself immediately and stays in control until the next cycle stop.
    Best wishes
