585,761 active members*
4,033 visitors online*
    Hello everybody
    I am looking for a possibility to jump from a main program ( work piece 1. WPD) into a ‘program part’ of another main program (work piece 2.WPD) on a Index G200 (Siemens 840D controller)
    The manual says that I should write MPF+ program name. ( manual programming).
    However it doesn’t work. It can’t find a program.
    According to the book:
    Search strategy of the controller :
    1.Is there a *_MPF?
    2.Is there a *_SPF?
    The command EXTCALL ‚work piece 2‘ doesn’t work either.
    Looking forward to your answers.
    Aug 2008
    242
    Hello
    I guess it’s not possible to jump into another WPD.
    Can you not integrate the necessary program parts into the existing work piece? ( via UP)
    Regards
    INDEX service
    Hubert Dieterich<br />Technischer Kundendienst<br />Index-Werke GmbH &amp; CO KG<br />Hotline: +49 (0)711 3191 600
    Hello
    Regards
    INDEX service
    Ok according to the manual it works.
    So, I jump from a WPD file into the sub program of another ‘loaded’ WPD file.
    Manual: work preparation from page 163
    Yes it works, It was already possible on a INDEX GFG250 with Sinumerik 3T controller
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
