584,805 active members*
4,987 visitors online*
    Jun 2005
    101
    lb30mw
    ospu10-l
    hi @all
    Is it’s possible to program the piece counter with the controller. If possible without subprogram.
    We mainly process parts where 3 rods are peged out after each other,
    I coundn’d find anything about it in the manual
    thx@all
    Oct 2004
    85
    yes, for that I make use of variables and compare them at the program end and as long as they are not the same, the gripper continues to draw the rod in and the machine does as many parts as I tell it to do.
    When that is fulfilled, then the machine stops automatically and i can insert a new rod.
    Regards
    Jun 2005
    101
    Well for that I can also insert our piece counter at the end e.g. 50 and then the machine also stops with the error “overvalue in piece counter”,
    No, I am only interested in the command for the piece counter as I said without subprogram...
    Jun 2005
    101
    so e.g.
    pick up part full length for e.g. 3 pieces
    Peg out parts with zero point offset (e.g. write)
    After the 3x pegging out, the program should write me the 3 pieces into the piece counter.
    Or even after the pegging out .. just without subprogram
