585,727 active members*
4,171 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Power Supply Transformer Question
    Jun 2006
    80
    I see most DIY power supplies use toroidal/round (did I spell that correctly?) transformers; is there any advantage over using normal "square" transformers?
    (my apologies if I posted in the wrong section)
    24220
    Advantages are, a bit more efficient, more compact for size, but the big one for the DIY'er is that they generally are easier to modify, (add/remove turns etc).
    Otherwise, you won't notice alot of difference.
    They became popular with Audio amp. builders due to the minimum radiated energy reducing hum pick up etc.
    Al.
    Albert E.
    Jun 2006
    80
    Quote Originally Posted by Al_The_Man
    Al.
    Does this mean they produce less EMI?
    snooper's second law: common sense isn't as common as we're led to believe...
    24220
    This is why they are more efficient, there is less radiated magnetic energy, the figures I have seen are up to 8:1 less than for square laminate types.
    Al.
    Albert E.
    Jun 2006
    80
    Thanks Al, seems like I'll start hunting for a transformer now! Proves again that "round" is better than "square"...
