585,997 active members*
5,027 visitors online*
    Hello
    I've bought a 500C Maho with the CAM program OneCNC XR3.
    The program has a memory of 24kb but it is still a bit too small.
    Therefore, I bought a 1mb memory card PN :4022-226-2340, does someone have any experience with this?
    Do I need to change the constants, so the card can be detected? If so which ones? Unfortunately I have no legend of the constant....
    I have the software version6 097/405. Is it possible to get the current version?
    Thank you very much
    greetings
    Steffen
    Oct 2007
    123
    Hi Steffen
    I hope you did not spent too much money on it. As far as I know, the memory card 4022 226 3340
    equipped with 1Mb only runs from a 10Mhz CPU hence from software version V600 onwards
    I am sure that the DMG guys can get you a clear text of machine constants....
    An upgrade is only possible if you can have the necessary parts (CPU and software).
    greetings
