Hello
I got a Maho 500c with Phillips CNC 432 controller for hobby purposes.
It should run but after the transport....
The problem:
I can turn on the machine.
The hydraulic is running.
When I select” approach RP” and press start, then the position display of the particular axis starts and goes until the servo lag is reached, then the machine goes to Emergency Stop and it displayed X04, Y04, Z04 (servo lag alarm). In Tipp modus it’s exactly the same. When I turn the axes manually then the position display continues counting properly and then the machines goes into emergency stop with the error X07 - (stand-still monitoring)
Has anybody got an idea what the problem could be? Or has anybody experienced a similar problem?
Kind regards
Christoph
