585,692 active members*
4,903 visitors online*
    Hello
    I get the error messages M01 and #05 on my Maho. Can anybody help me out??
    Hello
    the #05 is the emergency stop on the machine as a consequence of the error M01.
    Error M01 is a Checksum-error in the constant memory. The reason could be:
    Battery empty, machine parameter out of range, hardware error on the CPU
    Its best to remove the CPU (if possible save all data beforehand) , the wait a few more minutes and build it in again.
    Enter the parameter again (override) then the CPU should work again...
    Regards
    <a href='http://www.ersatzteilcenter.net' target='_blank'>Online ersatzteilcenter für Werkzeugmaschinen</a>
    Ok, I ordered a new battery yesterday (KUHN) Then I hope the error message will be gone after. If it’s really the CPU then don’t have a clue how to dismantle the CPU and build it in again...
    Thank you again
    Regards
    Patta
