585,973 active members*
4,013 visitors online*
Results 1 to 6 of 6
    Hello everyone
    I am new in this forum because I have the following problem: my Maho MH 500 W, an elderly model, continuously looses it’s machine constants.
    I have read that there is a buffer battery somewhere and the machine constants are saved in there.
    Apparently its somewhere in the cabinet but I can’t find it. Can anybody help me to find that battery?
    Many thanks
    Hello
    what controller does the machine has 432-9 or 432-10 ?
    Regards
    Mtronik
    <a href='http://www.ersatzteilcenter.net' target='_blank'>Online ersatzteilcenter für Werkzeugmaschinen</a>
    Jun 2005
    889
    A small tube like the case of a cigars about 80-90 mm long or longer.. usually somewhere where you can see it but still oversee it.
    In there, when opening the head, could be 1-3 batteries,
    Never change them when the machine is switched off!!!
    Leave the machine on... the purpose if these things to buffer when there is no power available and to keep the brain intact. If you take it out when the machine is switched off then who supplies the brain?
    Other possibility: a button cell as big as a 50 cent piece in the central cabinet..Although that technology is younger.. maybe from the 1995?!?!?!... About that i would say...
    Hello mtronik
    A very good question. I can see in the electric circuit plan that it’s a 432/15. The version number is 6702 703/1... does that help? If not where do I find the number that you need?
    The machine is a MH 500 W4 Series 609.
    Best wishes and have a nice weekend
    Unfortunately I couldn’t find a cigar case....Nor a button cell.
    I am a bit scared unscrewing the cover as long as I don’t know what I need to get rid off..
    Many thanks for your help!!!!
    Hello
    You can find the battery in the power supply underneath the controller (aluminium-box at the bottom right)
    The power supply is adjusted with 2 Imbus screws. Unscrew the screws and then pull it out 2 mm forward.
    Now you can pull of the two flat plugs on the right side. However before you need to mark them as you should never mix them up.
    Afterwards you can pull of the white flat plug in the middle. Now you can pull out the power supply completely, the battery is situated in the back.
    6V 4AH
    With you buy a new battery watch out for the + and the – because otherwise the voltage controller is ruined.
    Regards
    Mtronik
