585,996 active members*
4,425 visitors online*
    I have a Maho MH 1000C ( Philips 432). The power supply of the CNC controller is probably damaged
    Can anybody tell me how I could check it and what I need to consider when replacing the power supply with a new one?
    Hello
    I guess that your power supply is on the right side of your controller.
    With these power supplies you don’t have the possibility to check the voltage.
    Unless you take the controller completely apart. Then you can measure the voltage on the backplane.
    Regards
    mtronik
    <a href='http://www.ersatzteilcenter.net' target='_blank'>Online ersatzteilcenter für Werkzeugmaschinen</a>
    Do I have to consider anything when taken the controller apart?
    I already read out the parameter...
    Hello
    You only have to mark the plugs
    Regards
