585,573 active members*
3,501 visitors online*
    Oct 2005
    34
    Hello
    After I connected a new battery to the power supply and entered the machine parameter again, I get the error message ERR I 05 on the controller.
    I got the machine second hand and I never used it before.
    A second person already tried out pressing button 7S2 but without success.
    Behind in the control cabinet is a component part that shows me a feedback after the hydraulic button on the controller is pressed.
    I also placed the axis manually so far away from the end switch that it cannot be the cause of the error. I would like to know what component part is responsible for the error message. Then I can exclude several things.
    Would be great if anybody could tell me what the error message could include.
    Many thanks in advance
    Kind regards
    Tobi
    Jul 2002
    104
    Hello Tobi
    But you know how to switch on the machine: hydraulic + clear control
    It’s a simple answer but you never know who stands on the machine... smile.gif
    Kind regards
    Hugge
    CNCMarci Guest
    Hello Tobi
    Kind regards
    Hugge
    Hello
    As far as I remember, hydraulic + clear control is only necessary when error I01, I01 occurs when switching on the machine-> so controller not on voltage....
    I think I05 is an emergency-turn-off message
