585,743 active members*
5,049 visitors online*
    To all Röders controller users!
    Who has tested this new program or paid over 4000€ to use it permanently!!
    We got an offer for the editor 150€, the simulator with cycles 700€ and the complete version for around 4400€ and we currently started testing the system on two machines.
    What we don’t really like is the measuring e.g. a simple height change and the reference of the geometry to the tool zero point.
    Has anybody has any experience with it?
    Kind regards
    Take-it-easy
    Are you talking CnCCalc?
    I have the program from the beginning and I get along with it very well apart from a few things.
    What problems do you have in detail?
    Hello Elmoh!
    I mean the program RMS edit.
    Röders has offered it due to our demand for shop programming.
    Then we found out that there is a better editor in that program than the one we work with on a daily basis.
    On top of that we currently try out the use for the shop programming.
    The difference to the commander is immediately recognisable.
    The commander program is based on parameters. The new software is CAM based- hence no G41 path correction. However we cope quite well with the detail programming with the online help.
    It is often too detailed but then the last few obscurities are not explained.
    What system do you use to program a fit that need to be accurate to +-0.008 and where you want to feed on the machine yourself.
    Kind regards
    Take it easy
