585,582 active members*
3,786 visitors online*
    Hello
    I have a Traub tnd 360 tx8h that just switches itself off after 6-11 hours of production.
    After the error message ’auxiliary drives temperature probe’ occurred once, it’s a lot harder to get the machine running. Always the same error message comes up.
    Next day the machine works well and then suddenly the same game again.
    My question: Can you cool the machine down or bypass the problem? Where is the temperature probe situated?
    Would really appreciate if anybody could give me some advice!
    Hello
    The error message occurs on our TNA 400 when long chips got pulled into the chip conveyer as then the conveyer’s drive gets overheated. When its overheated, the lift gate for the engine flies.
    Solution: restart lift gate, reset the controller and then you can make the chip conveyer move backwards so you can eliminate the blockage.
    Check if the conveyer is clamped or if the drive is hard to steer somehow.
    Hope I could help you!
