586,024 active members*
4,172 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Index and Traub > TND 400 TX-8F program run from the computer
    Hello everybody
    I would be interested to know if it’s possible with the TX-8F to transfer the program in blocks from the PC.
    I know that system from our Heidenhain controller : the transmission starts on the PC and I only confirm it with the NC start button on the machine.
    I would need this block transmission due to the program size.
    Many thanks for your help.
    Hello again
    I haven’t found out anything. There was supposed to be a program called WOPCOM that was able to do it, but it only works under DOS.
