585,743 active members*
5,136 visitors online*
Thread: PC-error 10
    Dec 2007
    4
    Hello,
    My Traub TNS65 with TX8D controller always displays the PC errors 10. Does anyone know about this? Does the card need to be replaced and can the error be eliminated?
    Error no. 10 is a validation error of the memory card FX15, which controls the PC functions. Sometimes it is sufficient to pull the card out again and re-insert, of course when the NC is switched off, because it makes such a thing due to contact problems.
    If nothing works, a replacement will be required. Sign up via PM with us.
    good luck
    <span style='color:green'><span style='font-family:Arial'>Wenn dich jemand um eine Information bittet, dann will er nicht deine Meinung hören.</span></span>
