585,764 active members*
4,144 visitors online*
Page 3 of 3 123
Results 41 to 46 of 46
  1. #41
    Oct 2006
    74
    Colin,
    I don't know why your disconnecting the ball screw but if you want to take it out an sell it I'm interested in buying it. If you do remove it be very careful to not let the ball nut run off the end of the screw. If you do you'll have a few balls to find.
    Bob
  2. #42
    Oct 2006
    74
    hsmcnc,
    Here is a file from my archives. It makes a header plate for a small block chevy cylinder head.
    Have Fun
    Attached Files Attached Files
  3. #43
    Jul 2005
    19
    Bob,
    Thanks for the code. Everytime I power down the machine I lose the program I have entered. I assume the battery is dead. I have attached a picture of what I think is the battery on the Orange tabbed board. Can this be replaced? It sure dosen't look good.
    Eric
  4. #44
    Oct 2006
    74
    It is very simple to replace. try jameco.com for the battery.
  5. #45
    Apr 2008
    6
    Quote Originally Posted by luiguicam View Post
    Eric,
    I am glad you find a way to make your machine work. If the problem is the monitor, it is not big deal to fix it. When your machine is finally working, you may need to put some programs into the control. I was dealing a lot with the communication settings and I added to the machine dripfree capability by inserting a relay and connecting some cables, getting enough memory to run large jobs. I have all machine squematics and manual in case you need them.
    Regards,
    Luiguicam
    I am interested in getting copies of the anilam crusader series m schematics if you still have them available.
    [email protected]
    Thanks,,
    R.J.
  6. #46
    Aug 2018
    20
    Re: Some Retrofit questions
    Me too if available please, [email protected]
Page 3 of 3 123
  1. Questions rf-31 retrofit
    By Mike Wood in forum Benchtop Machines
    Last Post: 01-03-2020, 08:59 PM
  2. NEED HELP - CamTech RetroFit Questions
    By jeff.peters in forum DIY CNC Router Table Machines
    Last Post: 07-19-2013, 09:12 PM
  3. CNC Retrofit questions
    By K_Labs in forum Maintenance DIY Discussion
    Last Post: 05-23-2012, 05:12 PM
  4. BPT Series 1 Retrofit Questions
    By bnoji in forum Bridgeport / Hardinge Mills
    Last Post: 07-14-2008, 07:34 AM
  5. Boss 6 S2 retrofit questions
    By jacampb2 in forum Bridgeport / Hardinge Mills
    Last Post: 04-30-2008, 06:48 AM
