585,597 active members*
3,492 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > HEIDENHAIN > HEIDENHAIN -> TNC > Milling of an ellipse in cone form with tnc 430
    Hello
    I’ve got the following question.
    I’d like to mill a semi-ellipse in cone form. And I can’t get ahead at a certain point.
    The data: height of the cone = 80, diameter at the top = 30, diameter below in Y=45 in X=30.
    Milling of an ellipse is not a problem. But how can I make the diameter=30 (in case of covering in Z=-1 to the depth Z-80) potentiate to diameter 45 in Y?
    I’d really appreciate if someone would suggest something.
    Hello
    It should be an easy exercise of three clauses:
    D1(30mm) - D2(45mm) = (-)15mm. The result divided by the step number (80) = 0,1875mm. It means you have to add 0,1875mm in every covering. For example, like this: Q1 = Q1 + 0,1875
    Good luck!
    Jul 2006
    809
    I’ve got a counter question:
    If the diameter above is 30mm and the diameter below has to be 45mm, how do you get at D45 below without destructing the D30 above?
    Frohe Grüsse Stefan<br /><br /><div align='center'><!--fonto:Comic Sans MS--><span style='font-family: "Comic Sans MS"'><!--/fonto--><!--coloro:#FF0000--><span style="color:#FF0000"><!--/coloro--><!--sizeo:6--><span style="font-size:24pt;line-height:100%"><!--/sizeo-->Ein Tag ohne lächeln ist ein verlorener Tag<!--sizec--></span><!--/sizec--><!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--></div>
    Feb 2009
    170
    Yes Stefan, you’re right, but he wants an ellipse as a cone, meaning outside contour. I believe it should be like this, but I’m not really sure:
    [attachment=8587:Bild1.png]
