585,729 active members*
4,551 visitors online*
Results 1 to 6 of 6
    Hello and good morning everybody
    Our Z axis display doesn’t count anymore since yesterday.
    Or rather it only counts the 5/1000th.
    The measuring stick still works- we have tested it.
    Does anybody know a reason for it? It just happened out of nowhere.
    Maybe a component part is defect or something.
    I hope somebody is able to help me out.
    Kind regards
    Jan 2004
    229
    Hello
    Are you sure that it ever display one thousandth?
    Regards Gazzo
    Hello
    Regards Gazzo
    Hello
    The display doesn’t show one thousandth- it shows 5/1000th. They are still being displayed!
    Dec 2001
    5151
    The TNC121 shows a maximum of 3 post decimal positions in max. 5/1000 steps- the 3rd position after the comma is always a 0 or a 5-
    But please can you explain your problem more detailed
    I understand it that only the third position after the comma counts?!- If yes, then the display of the other positions is dead or frozen?
    <b>Gruß / Regards</b><br /><i><b>CNCFanatiker</b></i><br />AdminCrew<br /><br />Wenn wir immer das tun was wir können, dann bleiben wir immer das was wir sind.<br />If we always this act what we are able to do, then we always remain what we are.
    Hello
    So, I switch on the machine. X,Y and Z are of course equal to 0,000.
    When I change something on the Z axis, then the display goes to 0,005 and after again to 0,000 (instead of 0,010), then back to 0,005 and so on.
    Meaning the millimetre, tenths and hundredths always stay on zero.
    Kind regards
    Jan 2009
    376
    How did you test it? Switched Z for Y? Does a different glass scale show the same behaviour when you connect it to the output of the Z axis?
