585,982 active members*
4,385 visitors online*
    Salut everbody
    I am working with a Mikron WF 41 C ( TNC 155) and I want to download programs from Rhinocam via Server (TNC Remo).
    So far it never worked, or rather only half of the programs were transmitted.
    My question:
    What exactly do I have to set on the TNC (parameter)?
    How high can the Baud rate be?
    What exactly is block by block processing`? Is the TNC 155 even able to do it?
    Many thanks for your help
    Just to add:
    My aim is to run big programs (5000 blocks) on the Mikron. However I already have big problems with small programs. Has anybody got experienced with the TNC 155 and REMOTNC?
    I am pretty helpless at the moment...
    I appreciate any kinds of advices!
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
    Feb 2010
    368
    Hi
    Could it be that the program memory of the TNC155 is not sufficient? If yes, then just transmit in blocks. That means that the first part of the program is transmitted and processed. When that is done, then the rest of the programs is transmitted.
    Regards
    Stefan
