Originally Posted by
arenamember
Hello
thank you for entering in my post
I've just downloaded a demo version of iTNC 530 on my laptop with Windows Vista
I'm not able to write a program like: insert the blank form or insert a normal line stating with L
I can get into the editing page > I can write the name of my program but then i can't do anything else
I've seen there are several foldes with many files on the top left of the screen, among this files, is there any examples of the program?
What are the main differences between a demo version and the proper software as I've seen it costs £2673,00 !, without any other components (like a keyboard) only the CD software with a manual
I know with a demo version you can write a program no longer than 100 lines, however the proper software to be so expencive, what does it have more?
Any information accordinfg thi matter will be very appreciative
thank you in advance for your help
Hello arenamember,
the trick I've given to you...
The only main differences ->
The demo version of the iTNC 530 programming station permits you to save up to 100 NC blocks per NC program.
When extracting contours from DXF files, the TNC saves no more than 50 NC blocks in the corresponding contour program. The same constraint applies to extracting machining positions into a point table.
The price £2673,00 is heavy but I can nothing say about.. in germany the programming station cost's € 2500
The dongle version is as I've heard probably cheaper - no idea if it's true but I've heard € 800
<b>Gruß / Regards</b><br /><i><b>CNCFanatiker</b></i><br />AdminCrew<br /><br />Wenn wir immer das tun was wir können, dann bleiben wir immer das was wir sind.<br />If we always this act what we are able to do, then we always remain what we are.
