585,722 active members*
4,274 visitors online*
    Aug 2008
    124
    Hello everybody
    I am working on a Hermle C42U with iTNC530 SP6.
    Now I have a work piece where I have to level 4 pre-existing dill holes with the spindle. I have pivoted the piece upwards (A-90) and probed 2 points in Z and adjusted the C axis- that worked.
    Now my problem: as there is no probing cycle for the zero point setting for 2 drill holes, I have used 4 drill holes. However with 3 trials I had 2 coordinate systems- that’s not how it should be.
    I hope somebody knows an easier solution. Otherwise I will probe and measure 2 already driven drill holes. Then calculate the middle of the Q parameters with the help of the measured values.
    Regards Nike
    seit über 20 Jahren habe ich Erfahrungen mit folgenden Steuerungen: TNC 151, TNC 155, TNC 407, TNC 426, TNC 430, iTNC 530, iTNC 530HSCI<br />und folgenden Maschinen: Hermle UWF 712, UWF 851, UWF 1002, UWF 902, UWF 1202H, U630T, C800V, C800U, C20U, C40U und C42U. Zeiss-Meßmaschine<br />CAM: OPUS<br />ein wenig Erfahrung hab ich dann auch noch mit: Hurco-Fräsmaschine, Mitutoyo-Meßmaschine<br /><br />im Bereich Erste Hilfe: Rettungssanitäter
    Dec 2001
    5151
    Hello Nike
    If you need the program more often, then I would definitely write it over calculating the middle with Q parameters... the less fine method would be still using cycle 418.( the one for 4 drill holes) and then write the same coordinate into drill hole 1 &2 and 3&4... Also not intended by the inventor... but it works for a “snapshot”...
    What do you mean by 2 coordinate systems with 3 attempts? Maybe you can show us your program?
    <b>Gruß / Regards</b><br /><i><b>CNCFanatiker</b></i><br />AdminCrew<br /><br />Wenn wir immer das tun was wir können, dann bleiben wir immer das was wir sind.<br />If we always this act what we are able to do, then we always remain what we are.
