584,866 active members*
5,003 visitors online*
    Hello everyone!
    It’s about a DMF 260/7 with X Y Z B C axis and 3D measuring probe.
    Is there a possibility to touch several points on the face and if the difference of these points in Z is giver than 0,05mm then the processing is automatically stopped/ or an error message is released.
    Regards Lucas
    Sep 2008
    2312
    Hello
    Try and use cycle 427 consecutively.
    The first touch point is the conductance ( saved in Q160)
    Q60 = Q160; buffer conductance
    Q61 = Q60 + 0,05 ; tolerance above
    Q62 = Q60 - 0,05 ; tolerance below
    Then you add the tolerance values after.
    Gruß<br /><!--fonto:Comic Sans MS--><span style="font-family:Comic Sans MS"><!--/fonto-->Schwindl<!--fontc--></span><!--/fontc-->
