584,802 active members*
4,881 visitors online*
    Hello
    I try to make sense of the demo version and I already have a problem.
    How can I edit single program block, where I want to change the data?
    For example when I called a cycle and I enter values that I want to change again afterwards.
    Also when I want to change a line for example.
    So far I always deleted the program block and then entered a new one with new values. I am sure that’s not the ideal solution... Please explain it “idiot-proof” as I am a beginner
    Thank you
    Michael
    Hello
    When you press the combination Ctrl + Alt+4 on the computer at the programming station, then you get to the “program save/edit” mode. There you press Ctrl + Alt+P and you get to the PGM Manager. There you choose your program that you want to open and edit.
    Here you can select the block with the right arrow key on the keyboard. You get to the simulation with Ctrl + Alt+R. There you open again the PGM MGR and open the program that you want to simulate.
    Regards
    Manuel
