Hello everybody
I have a MILLPLUS v321 with serial port.
Can I transfer data from HH to this controller with help of TNCRemoNT?
If yes, then what and how do I have to set?
Hello everybody
Hello Volkmar
It’s possible to do with LSV-2-protocol. Activate connection (Heidenhain-software) LSV-2 in configuration.
Under setting take away a checkmark at rate of transmission and set baud rate.
The machine constant 770 at Millplus has to be set on value 4.
Regards
Hello hardy9892
Thanks a lot!!!
I’ll try that.
Regards
Hello hello
I know that the theme is already old.
@Volkmar
Did you have success and connected the Millplus with TNCremont?
I spent 3 hours today making a backup because I had to choose each folder separately at the machine (DMU 125P Millplus V400) to be able to back up the data.
Regards, Rene
Seid Oktober 2008 an DMU 80 P u. 125 P mit iTNC 530<br /><br />vorher 6 Jahre DMU 125 P mit Millplus V400
