585,758 active members*
4,339 visitors online*
    I urgently need your help.
    We bought a 10-year-old DMU80T with controller MILLPLUS V400.
    When we try to start it up, the error I01 (gateway disconnected) occurs.
    Turning on with the Clear button and the main switch remains ineffective.
    What gateway is meant? How can the problem be solved?
    I’d appreciate your help.
    I’ll also post the solutions
    Dec 2007
    198
    Hello
    Is the emergency switch in its initial position?
    Then, do you press the switch button first and immediately after that the CE-button?
    You have seen the machine in action, haven’t you?
    Greetings
    Dec 2007
    146
    Hello
    Exactly, first you should check up, whether the emergency switch is out, also at the hand wheel! I’ve once searched for it until I was blue in the face cause I hardly ever use it.
    Then, I had to open and close the door in order to lock up the door switch!
    And then press the main switch and F10 at the same time. It should work then.
    Regards, Steff
