585,719 active members*
4,431 visitors online*
    I am looking for a possibility to automatically open the door at M0. Is there a not documented M command for that?
    THANK YOU
    Nov 2011
    5
    As far as I know, it only possible to adjust it in the machine parameters.
    Our DMU50 opens e.g. the door automatically with M0, however machines from the 60s and 80s keep the door closed with M0.
    I am not aware of a not documented M command.
    Kind regards
    SKa
    Aug 2007
    413
    Hi
    Until the V530 there is a machine constants that is responsible for it - however I cannot tell you what it’s called at the moment.
    From the V600 onwards the opening of the door with M0 is controlled over the machine parameter „MS_CabinDoor_with_M00_open“.
    With G322 N5="CfgOemBool:MS_CabinDoor_with_M00_open:val" O2=1 (possible at the end value) you can read out the condition.
    In Parameter ES1 either “true” or ”false” is displayed.
    You can change the parameter over the USER-MOD function.
    Regards
