586,000 active members*
4,922 visitors online*
Results 1 to 2 of 2
    Nov 2007
    270
    Hello at all,
    I've got the following question.
    Normally we programm via machined part ever.
    I mean: describe the contour at ''machined part'' and than process the contour at ''machining'' with G890 cycle.
    Is it possible to turning another feed for a face as specified at ''machining''?
    Greetings
    You can programm at your machined part a special feed factor for a face. The command is G38.
    Factor 0.5 means: when the machine's got a feed of 0,1 - this value is cutted into halves at the programmed face.
    Greetigs, Eternal Fire
