584,817 active members*
4,719 visitors online*
    Hello,
    is it possibleto print a program, which I have written with PC Software Data Pilot 4290 ?
    Thanks in advance.
    Hello,
    yes you can. There are 2 possibilities.
    Either you follow the path in Explorer, which is given in the program:
    c:ProgramsDP620...ExampleVnc_progncps
    or directly from the manual plus surface.
    Open program - mark all
    Extra
    BLOCK
    Copy
    than insert in Explorer and print.
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
