585,981 active members*
4,288 visitors online*
Thread: Single block
    Feb 2008
    98
    Hello
    Who can give me a tip to the following problem:
    When I want to start a new program, I turn on a single block. It works for all operation moves, but why not for if-then-else commands?
    Can I control it anyhow?
    Jun 2006
    179
    Talking
    Hello
    A block can’t be exactly declared with if-then-else commands
    Try M0 new line and STOPRE after each command, then you’ll see the ropes…
    Greetings
    Die Tage werden kürzer und der Winter naht...
    Oct 2005
    659
    SBLON block on
    SBLOF block off
    Maybe it’ll work…
    <span style='color:blue'>Mit freundlichen Gr
