585,712 active members*
4,362 visitors online*
Thread: G641
    Hello dear community
    Does the path subsequent grinding has an effect on the Z axes?
    Let’s say that’s how the program looks like:
    N01 G0 G641 Adis=0.5
    N02 G0 X10 Y10 Z0 S5000 F200 M3 M8 M7
    N03 G1 X0 Y0
    N04 G0 G64 Z10
    Does the grinding in N02 also influences the Z axes or just the X and Y one?
    Would really appreciate your help.
    <b></b>Vielen Dank f
    hapo Guest
    No, in your example G641 is only effective from the block crossing onwards so from block N02 to block N03, because with N01 you don’t command a movement.
    And yes, it affects the path and therefore all involved axes.
    If, for example, you would have an additional ADISPOS=7 in block N01.. then the machine would run with 7mm grinding distance at the block crossing between the rapid traverse blocks.
    First of all thank you.
    So if I program:
    N02 G1 X10 Y10 Z0 S5000 F200 M3 M8 M7
    N03 G1 X0 Y0
    N04 G0 G64 Z10
    So it could be that Z is not at zero, doesn’t it?
    In the old example ( see above) it doesn’t influence it because it’s a G0 movement and I haven’t programmed a g641 adipos=, correct?
    Thank you!
