585,719 active members*
4,544 visitors online*
    Hello colleagues
    Can anybody tell me where the milling time (start with PROTON, End with PROTOFF) is saved on a 840D and how I can read it out?
    Kind regards
    Joe
    Hello falcon_x
    I think that you can solve it with a timer ($AC_TIMER) and then read it out with a R-parameter that is not used yet.
    E.g.
    $AC_TIMER[1]=0
    PROTON
    PROTOFF
    STOPRE
    $AC_TIMER[1]=-1
    R3=$AC_TIMER[1]=-1
    Regards
    Hello Thilda
    Thank you very much for your quick help!
    Regards
    Joe
    I have tested several alternatives in Sinutrain. However without PROTON/PROTOFF.
    However the error message unauthorized"Array-Index1" comes up continuously.
    Either the software cannot cope with it and I have to check it on the machine.
    Or do I have to activate anything?
    I can’t find anything in the documents...
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
    Mar 2006
    124
    Hello
    I think there is a mistake
    try
    R3=$AC_TIMER[1]
    Instead off
    R3=$AC_TIMER[1]=-1
    Now the time (in seconds) should get displayed in R3
