Hello
I am new here and I urgently need help for my upcoming task. (controller 840D 3 axis vertical)
I have to process a few parts in which I have to mill an ellipse.
The only imaginable possibility would be immersing into the material with a radius cutter and run a radius in Z minus direction ..That works quite well so far. Only I overlooked the necessary cutting radius compensation. After I milled the first part it was clear to me. I run the radius solidly and with the tip of the radius cutter.
I need special help for the compensation for the radius miller in Z-direction.
In the tool memory I am able to store 3D tools without problems.
But how can I describe a contour in Z/X direction?
Processing the radius in a solid manner would distort the result towards the outside.
The dimensions: Radius 12.5 (the radius cutter has the same) on radius 28.5; depth:10.5
Many thanks in advance
