586,005 active members*
5,078 visitors online*
Thread: Siemens 810D
Results 1 to 6 of 6
    Hello!
    I want to tap 10mm over the middle axis with a turning machine. Can anybody tell me the required commands?
    Thank you
    TIM
    Sparsely details!!!
    How deep?
    What Z-position?
    With or without compensation chuck?
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
    about 12 mm deep without compensation chuck, the problem is that its not processed from the model axis but above it..
    hapo Guest
    That only works with a real Y axis:
    G19
    T="GEW_M10_RAD" D1
    SPOS=0
    M2=3 S2=300
    DIAMOF
    G0 X50 Y10 Z-10 ;pre-positioning
    G97 G95
    CYCLE83(50,30,1,,10,0.2,3,,0.5,0,300,500)
    DIAMON
    G0 X500 Y0 Z500
    G18
    .. but don’t forget to drill the core hole beforehand
    So axial in X10?
    Where is the problem?
    Are AGW(workplace limit values) available?
    Ah- so radial offset in Y 10mm
    Unfortunately nothing is available!
