585,758 active members*
4,608 visitors online*
    Sep 2004
    56
    Hello everyone
    I want to take the mean of a component part with a 840 DSL controller with the help of measuring cycles....
    What do I have to do? The component part is 700mm wide and I wanted to measure 4 points and take the middle...
    I wanted to use measuring cycles and if it’s possible not the 1-point measurement cycle 978
    Would be thankful for any kind of help
    Kind regard
    hapo Guest
    If you have a 840Dsl, then I am sure ShopMIll is installed.
    In Shopmill all thinkable measuring cycles are provided.
    Why do you want to play with DOS, if you want to use Win7?
    Or have a look in the manual measuring cycle in DOCONWEB.
