585,987 active members*
4,623 visitors online*
    Hello everyone
    Following problem:
    I have a component part with 10 pockets
    Now each pocket should be pre-roughed with a big cutter and afterwards the residual material should get removed.
    For that, I have 10 contours with 3 milling tasks each in Shopmill, of course that take a very long time because the machine does a tool change after each pocket.
    I would prefer that it processes all pockets with one cutter and then it removes all of the residual material with a second cutter.
    How can I influence the order?
    Be aware, I am still a newbie =)
    Regards
    Mts
    A contour with one technology is sufficient.
    Set TRANS X, Y and repeat technology.
    You don’t even have to be able to master the Siemens controller, that is everyday life.
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
    But these are 10 different pockets. Similar, but still different.
    Hello
    Can you explain this a bit more in detail?
    Thank you
    OSCHI
