585,975 active members*
4,531 visitors online*
    Dec 2005
    51
    Hello CNC community
    Does anybody have any experience with traversing to a stop? Is this function an option?
    Background: I want to check with an empty holding fixture if a moulded drill hole is available or not.
    I would immerse with a small momentum with the intake into the drill hole by using the function.
    When I reach the final position then it means the drill hole is available. If the function stops the movement of the Z axis before, then no drill hole is available.
    Could that work? Does anybody have an example program?
    Regards W06Fan
    hapo Guest
    Yes, but not with G75.
    Traversing to a stop is a payable option.
    If it’s active, you have to consider several things when you want to use the function as you explained.
    Clamps:
    G1 G95 Z-5 FXS[Z]= 1 FXST[Z]= 10 FXSW[Z]=2 F200
    Resolve:
    G0 G94 Q1=400 FXS[Z]=0
    G1 Start up has to happen in working feed rate!
    Z= Axis should run to end stop
    FXS[Z] =switch on function (= 1) or switch off(= 0)
    FXST[Z] =axis power in % (Torqe)
    FXSW[Z] =Size of the monitoring window when released in mm
    F =feed for the approach
    You have to enter the axis name in the function, not the geometry axis. Z could also be called Z1.
    Because the function is designed that the axis should encounter resistance – so if the axis runs into nothing, then an alarm is released. The alarm message has to get switched off with $MA_FIXED_STOP_ALARM_MASK.
    Now the condition of FXS has to get analyzed and corresponding action has to get triggered.
    $AA_FXS[X]
    Status target state „traversing to a stop“
    0: axis not in stop
    1: end stop approached successfully
    2: Approach of the fixed stop has failed
    3: Selection drive to fixed stop is active
    4: end stop was recognized
    5: deselecting drive to fixed stop active
    case ($AA_FXS[Z]) of 1 gotof LAB1 2 gotof LAB2
    LAB1:
    G0 Z400 FXS[Z]=0
    VORBOHREN
    LAB2:
    G0 Z400 FXS[Z]=0
    PROCESSING
    I would recommend starting the trial with a small FXST value. The drive should just about to be able to move the axis.
    Values > 30% are usually already dangerous for the axis.
    You will find more in the programming manual working preparation and in the list manual of the system variables.
