585,753 active members*
3,882 visitors online*
    Hello guys
    Today, I have worked with the ‘brisk soft drive’ command- it was all fine so far. However I wanted to have it only for one axis so I wrote for example DRIVEA(AX3): that should be the z axis on my machine.
    Now the error message Z1 axis is the wrong axis type. Has anybody got an idea?
    Regards John
    Jul 2008
    921
    Hello John
    Try to get rid of the ! - then it should work. Otherwise you need to have a look how the manufacturer names the axes.
    Generally about the word BRISK: It all goes a lot faster but it seriously strains the mechanics as the command switches off the acceleration ramp. In the long run, it’s bad for your machine.
    Regards
    Michael
    Hello micha
    Do you mean I should leave out the brackets? Because I don’t use an exclamation mark.
    I know that it puts a strain on the mechanics- I can hear it rumble.
    I only want one axis to go a long way. Where do I have to look? I had a look in the service display of the axis and there Z1 is axis 3.
    Regards
    hapo Guest
    Try
    DRIVEA(Z1)
    I want to add that when you have long traverse paths, you can’t expect an improvement regarding the processing time
    But: Trying out makes smarter wink.gif
