SFM G96 G50S2000 Max Spdl Speed
This is how it should work when using SFM (Surface Feet Per Minute), with the exception of the spindle rpm going up to 4000rpm. I believe you have a bad something somewhere in your control.
Here is an example of a Fanuc 10T Program for a Dainichi BX45 1987.
O1212
(GM 11700 PILOT)
(DRWNG=GM11700P.CAD)
(MATERIAL=SAE 1018)
(OP1)
(DATE 12/10/03 PGMR TJD)
(DATE REV 12/10/03)
(T1=CNMG432 HORE. T3)
(T2=DNMG431 HORE. T3)
(JAWS= PRESS= )
(CYCLE TIME=M S)
G0 G40 G97 G99 T0 M5
G28 U0 W0 M9
G50 S2500 M41
M1
N1 (R-FACE/TURN)
G28 U0 W0 T0
T101 M8
G96 S500 M3
G0 X2.5 Z.2
G72 P10 Q15 W.002 D300 F.008
N10 G0 G41 Z0
N15 G1 X0 F.004
G0 G40 X2.4 Z.1
G71 P20 Q25 U.02 W.002 D850 F.01
N20 G0 G42 X1.402
G1 X1.702 Z-.1 F.003
Z-.5 F.005
X1.908 F.004
G3 X1.9576 Z-.5221 R.025 F.002
G2 X2.33 Z-.6875 R.1875 F.003
G1 Z-.76 F.005
N25 X2.4
G0 G40 Z.2 M9
G28 U0 W0
G97
T0
M1
N2(F-FACE/TURN)
G28 U0 W0 T0
T303 M8
G96 S750 M3
G0 X2.5 Z.2
G70 P10 Q15
G0 G40 X2.4 Z.1
G70 P20 Q25
G0 G40 Z.2 M9
G28 U0 W0
G97
T0
M30
Their are a number of things to check. First set the work shift z+ 4.0 inches away from your work peace. Next edit your program removing the G50S2000M3 and change the SFM G96S120M3 to G97S1200M3. Run your program in low rapid and see if you get the same results in spindle rpm jumping to a higher level than you programmed. If it does your spindle encoder is bad. If not, it may be a parameter problem.
One big question is how long have you had this machine?
The other problem you are having with the taper not working properly tells me that maybe there is a problem with the X axis position communication with the spindle is bad. If the encoder in the spindle doesn't know where the X axis position is it will do eratic things. If the encoder in the X axis is bad the machine should Alarm out and shut down. Runaway machines are extremely rare. The only experience I have with a runaway machine was a machine that was improperly grounded in a shop that did a lot of welding work on an extremely hot day (100+ degrees F in the shop) .
My best advise to you is to get a Tech in to look at it right away. The way that the machine is acting makes it a potential danger to you and everyone else in the immediate area.
I can't really tell you what is wrong, but I can tell you G92 is a Threading Canned Cycle. And the machine shouldn't be exceeding the (G50S2000M3) Max Spindle Clamping the RPM.
I wish you the luck that maybe it is a loose wire or an easy fix.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
