585,760 active members*
3,833 visitors online*
Results 1 to 1 of 1
    Post
    Hello,
    We using TRAORI function for swivel head. TRAORI type is 24.
    now when our A axis is rotating after TRAORI active z axis is moving on positive direction(according to machine Z axis should move to negative direction). we tried by changing Z axis to opposite direction but that time X and Y axis movement is not perfect. please check below information and parameter(attached). and give us some solution.
    1. Axis origins
    X0 = front of table
    Y0 = right side of table (seen from front of table)
    Z0 = machine table surface
    A0 = spindle pointing downwards (6 o’clock position)
    C0 = spindle nameplate pointing towards front of machine (A axis gearbox pointing to back of machine)
    2. Axis directions
    X = positive is towards back of table
    Y = positive is towards left
    Z = positive is upwards
    A = clockwise (view from front of the machine backwards)
    C = counterclockwise (view from top of machine downwards)
    please help us..
    Attached Files Attached Files
