586,005 active members*
4,878 visitors online*
    Hello
    Could anybody explain the difference between the both measuring systems mentioned in the topic head?
    Thanks in advance and kind regards, Hans
    Jul 2008
    921
    The 840D can work with the both systems. The system 1 is normally the motor measuring system, the measuring system 2 is the glass scale. So if the glass scale fails, at a pinch, it’s possible to go on working with the motor measuring system.
    Greetings
    Michael
