585,914 active members*
3,839 visitors online*
Results 1 to 6 of 6
    i want to know how to change the language from German to English in this control 810 t ga2
    machine heid cnc lathe
    type; s315
    model 1991
    want a solution to this problem as it is causing me many problems
    Apr 2005
    652
    Well, there must be a softkey "change language" available. This softkey you might see after pressing "Inbetriebnahme". This is the german word for start-up or settings. By pressing the Softkey "change language" in this menu the controller will automatically switch to english language. If there are only 2 language packets installed. If there are more than 2 language packets installed the softkey is called "language selection" In this case you press this softkey and then select the desired language.
    Gruß,<br /><br />Drehpapst<br /><br /><br />Willen braucht man. Und Zigaretten.<br />Wer Visionen hat, sollte zum Arzt gehen.<br />Helmut Schmidt
    Apr 2005
    652
    It might be that the "change language" softkey is written in german also. In this case the name of the softkey is "Sprachumschaltung".
    on the GA2 version you must change eproms
    language switching is only possible with version GA3
    There are only 10 types of people in the world: Those who understand binary, and those who don&#39;t<br />Wir haben einen exponentiellen Zuwachs an <strike>Doofen</strike> Pack im Forum
    Apr 2005
    652
    Quote Originally Posted by nixalsverdruss View Post
    Didn`t know that. So it is not that easy i thought.
    how to Chang ebrom in SIEMENS control 810 t ga2
