585,752 active members*
4,118 visitors online*
    Jan 2008
    48
    hello
    I’ve got a question about thread cutting without shim plate.
    Machine is Chiron FZ22 with Sinumerik 810M GA3.
    What do I need therefore?
    A special program?
    Or do I have to change parameters?
    I’ll appreciate any help.
    Horst
    Hello Horst2
    If you have the cycle G331/G332 at your machine, then you have everything you need.
    Greetings
    InTex
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
    Jan 2008
    48
    Hello InTex
    I’ll check tomorrow if the cycle is present.
    I hope it’s stored under cycles.
    If it’s not, where could I get it?
    Greetings
    Horst2
    Hello InTex
    Greetings
    Horst2
    @Horst2
    I believe you have the cycle because a cycle for thread boring has to be present even in a basic packet.
    Otherwise you’ll have to buy it at Siemens.
    Regards
    InTex
