Hello
I’ve got a problem with our CNC turning machine Niles N10. The CNC reports the following error: 2041 program is not in the memory. What should I do?
Hello
HelloHello
Very easy: just load the program to the memory.
You also should clarify why the error occurs.
Maybe your main program can’t find a subprogram because there isn’t any.
Or maybe there’s a main program but it hasn’t been loaded yet.
Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
Thanks for the rapid answer.
How is the program loaded to the memory?
Hello
How is your program made? Is it just a main program?
In this case, it works as follows:
Automatic mode
Input program number, for example %111
Program start
If there’s a subprogram, you just should have it in the memory.
If it can’t be found, it’s not in the memory or it has u number that differs from the number the main programs searches for.
