To compare a 810M with a TNC530i.... is like trying to compare a 327 BMW from 1926 with a Mercedes M class from 2011 ??!!
.. and then try do a chipturn with the 327 BMW ..
Have fun!!
…. Searching the chip
@ hapo
If you add your comment then at least write something useful to find a solution to the given problem. It ‘s no question that a 810M from Siemens can’t be compared to a iTNC530 from Heidenhain.
If you would have read the article properly you would know what QFT wanted.
@QFT
Unfortunately, I can’t help you out as I am not familiar with the cycle programming from Siemens. I believe it’s called CL800 programming. There are descriptions to this topic on the Siemens homepage to download. If I find out anything else I will let you know. Until then I guess you have to continue working with subprograms.
<b><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--sizeo:6--><span style="font-size:24pt;line-height:100%"><!--/sizeo--><!--coloro:#0000FF--><span style="color:#0000FF"><!--/coloro--><i>Gruß farmer</i><!--colorc--></span><!--/colorc--><!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc--></b><br /><br /><br /><br /><i><!--sizeo:4--><span style="font-size:14pt;line-height:100%"><!--/sizeo--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--coloro:#0000FF--><span style="color:#0000FF"><!--/coloro--><!--sizeo:4--><span style="font-size:14pt;line-height:100%"><!--/sizeo-->Hilfsbereitschaft, Gemeinsinn, Miteinander und Füreinander<!--sizec--></span><!--/sizec--><!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--><!--sizec--></span><!--/sizec--></i>
