586,005 active members*
5,075 visitors online*
    Hi
    I’d like to know what retraction feed motion you use during rubbing.
    I work with 840ds.
    Please with material, bore diameter and speed. It’s just for comparing.
    Thanks in advance
    Aug 2003
    278
    Hello
    Usually back with double feed compared to the one you pull in.
    So I move with 2mm per rotation out?!
    I.e. S=1000 U/min F=2000 mm/min
    Nov 2004
    2484
    Rubbing doesn't deal with controller! Technology is always the same!
    Important is what surface I need (Ra/Rz) and cutting material.
    HSS
    Hard metal charged
    Hard metal
    PCD
    Which do you have for which purpose?
    Regards
    Boern
    <b><br />Das dringendste Problem der Technologie von heute ist nicht mehr die Befriedigung von Grundbedürfnissen und uralten Wünschen der Menschen, sondern die Beseitigung von Übeln und Schäden, welche uns die Technologie von gestern hinterlassen hat.</b><br /><br />Dennis Gabor (1900-79), ungar.-brit. Physiker, Entwickler der Holographie, 1971 Nobelpr.
