585,898 active members*
5,077 visitors online*
    Hello does anybody know what to do?? We have an old Siemens controller 810D with the surface of the 840D.
    After a failure of the NC many cycles are not available anymore....
    Would be great if anybody could help me out!
    Nov 2004
    2484
    The 810D doesn’t have the surfaces of the 840D- both are identical, the 810D merely has a different hardware—just for your information...
    Have a look if the cycles can be loaded, if not then LAOD and RESTART the machine- then it should work again!
    Regards
    Boern
    <b><br />Das dringendste Problem der Technologie von heute ist nicht mehr die Befriedigung von Grundbedürfnissen und uralten Wünschen der Menschen, sondern die Beseitigung von Übeln und Schäden, welche uns die Technologie von gestern hinterlassen hat.</b><br /><br />Dennis Gabor (1900-79), ungar.-brit. Physiker, Entwickler der Holographie, 1971 Nobelpr.
    Thank you a lot for your advice. However I can’t select individual cycles anymore. They are simply gone!
