584,800 active members*
4,543 visitors online*
    Good morning
    On our Shopmill we have several programs that are stated with size 0.
    Recently an INI-file with size 0 always gets produced when programming multiple set-ups.
    Does anybody know how to delete this rubbish?
    Regards
    Caddy
    hapo Guest
    First of all you should check if the files are really empty ( in the program manager: cursor onto data INPUT)
    If the editor is empty, then you can delete the files.
    In order to do so, activate the soft key extension over the program manager ">" and select the soft key “delete file” in the right soft key bar.
    Then you can press the soft key “OK”
    Hello
    If that would be that easy then I would not post this question here.
    Regards Caddy
    hapo Guest
    Ok I forgot to mention that a file that was loaded in the editor cannot be deleted.
    So first close the editor or open another file in the editor.
    If is still doesn’t work:
    - Enter a few signs in the file that’s open in the editor and save it.
    - Close editor or open other file in the editor.
    - Select the file in the program manager and press the soft key „delete file“
    - Delete security query with the soft key “OK”
    With some software versions of the Sinumerik 810D/840D with hard disk (PCU50 or MMC103) it might be possible to first off load and unlock the file before deleting it.
