585,975 active members*
4,596 visitors online*
    Sep 2007
    405
    Hello
    Is there a possibility to program this cut-in (see attachment) with help of “cut-in cycles” in Shop Turn? Side faces are either “straight” or they continue in a certain angle up to the cut-in depth. How can it be combined?
    Thanks a lot
    Regards, vitra26
    Hello
    There’re several possibilities. The first one is usage of cut-in cycles. But id doesn’t make sense.
    Things like that are made with prick turning above the contour.
    Regards, InTex
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
    Sep 2007
    405
    Hello InTex
    Thanks a lot for your help. I’ll try that out.
    Regards, vitra26
