585,712 active members*
3,819 visitors online*
    Hello, I have a new machine without an opposed spindle. Log gripper in the revolver. I want to pull with the resolver and if applicable turn the C axle.
    My current solution is that is use start- up and shutdown and straight paths as well as M36 and M37. I just add it behind the program.
    At the moment I am missing the turning of the c axle to for example 75°.
    I haven’t found the function yet.
    Generally I don’t like it!
    For the cutting there is a nice cycle ( At Hainenhain I used to work always with g commands)
    There should be such a cycle to pull.
    My better solution would be with a subprogram. But I never done that with Shopturn.
    There must be several parameters handed over:
    Lengh of the part, width of Groove, Cutting length with plan turning, with or without c axle
    How can I do that with parameters and how can I come back form the subprogram (maybe with return)
    Please help me out, I am writing all our programs on the machine and I am the only one that know a little bit about this area. All other machines have Haidenhein with data pilot.
    Thanks a lot
    I do it like this
    F_HOME
    M05
    G04 F1
    STOPRE
    T= "GREIFER"
    G00 X100 Z=-R99+12
    G01 G94 F6000 Z=-R99
    G01 X0
    M69
    G01 Z0
    M68
    G00 X100
    M01
    F_HOME
    M17
    With polygon material you should program a spindle positioning after the STOPRE
    e.g. with a square SPOS=90 or hexagon SPOS=30
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
    Oh well it’s all in G code!
    Should also work with ShopTurn and straight line
    And what is the problem with G code?
    It will be deposited as a subprogram andselected
    with ‘RUN’ in the respective ShopTurn program.
    Oct 2005
    200
    Hello,
    I also do it with a G code subprogram. In the main program, I use 4R parameter. These 4 R parameter will be defined in the main program and only to access them the subprogram is opened. Similar with Intex.
    Greetings kani95
