585,737 active members*
4,543 visitors online*
    Hello
    I have problem with the correct simulation, I turn in between cone points.
    My neutral point is close to the jaw chuck and the measurement goes in the right direction towards the tailstock.
    So all + measurements!
    What has to be entered under ZI and ZB?
    Current display: the chuck is displayed somewhere on the piece.
    The processing works though... so is it only a display error or my error? Wrong values?
    Would appreciate a feedback
    Regards
    airwolf
    hapo Guest
    I am using my crystal ball once again...
    I guess a turning machine with Sinumerik.
    It seems that the tensioning mean is displayed; therefore it could maybe be a 840D or 810D with Shopturn. I can’t see if PowerLine or SolutionLine.
    In the program head of any Shopturn programs, the raw part is defined.
    Because the rest of the simulation is correctly displays, I guess that the processing lengths are not entered correctly like the display requires it.
    You should find out what you need to enter in ZI and ZB by using the Help pictures that you get after pressing the ‘HELP’ button.
    @hapo
    It goes in the ‘Plus’ direction if I read it correctly and there is also the duck in Shopturn... that doesn’t work... then my machine always complains about the processing direction!
    The Help button won’t help you out, maybe a raw part contour will put things right, it bypasses the entering of the head.... but it doesn’t matter anyway where the tensioning mean is displayed in the simulation as long as the processing is correct, isn’t it?
    <b><u><!--fonto:Comic Sans MS--><span style="font-family:Comic Sans MS"><!--/fonto--><!--coloro:#FF0000--><span style="color:#FF0000"><!--/coloro--><!--sizeo:4--><span style="font-size:14pt;line-height:100%"><!--/sizeo-->Ich weis nicht alles, ich lerne viel, <br />aber leider wird einem selbst das <br />lernen heute erschwert<!--sizec--></span><!--/sizec--><!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--></u></b>
    That goes in a positive direction- In Shopturn and also in DIN.
    In Shopturn you can decide what direction you choose.
    You enter ZI and ZB exactly as if you would program in Z minus.
    In case of need, raw part definition might be necessary.
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
